When i am in hi gear going 18 mph on paved road i have a vibration on steering wheel. 2300 rpms with R4 tires in 2wd. This is what it does......It vibrates for about 4 seconds then fades to smooth for 3 seconds and fades back into a vibration for 4 seconds and then fades back to smooth for 3 seconds. I feel it on the wheel but not really on fenders or anything else i can grab. Its not engine nor tires. It has something to do with drive shaft, transfer, u-joints, front gears or something to that effect i believe. The only thing i can think of is on 4wd vehicles the gear ratios are out of sync so they dont lock up and one is a little different then the other from front to back. This may be the case also with a tractor but i was in 2wd but im not sure if things still turn in front end to cause this or not. Its not tire rotation or engine for sure. help!
mike
mike
