TC55DA Stuck in neutral
   / TC55DA Stuck in neutral #1
TC55DA New Holland
Any help regarding my tc55da, seems to be in neutral. Worked fine the night before???
   / TC55DA Stuck in neutral #2
If you check the cable for the inching pedal see if it is frayed or out of adjustment would be a good place to look first.
   / TC55DA Stuck in neutral #3
double post sorry
   / TC55DA Stuck in neutral #4
I have a 2005 TC55DA that I bought new. Check the shifter switch !!!!!! It's under the dash connected to the shift lever. If water gets into it,its goes to junk. They have a new water tight switch as a replacement part. I have the new water tight switch now and have not had that problem for a few years. But a few days ago it acted up again, It was stuck in neutral. I pulled the dash cover off to find the jam nut on the cheap plastic shifter switch was loose tried to tighten it only to find it was cracked. A little JB weld and that problem is solved.
PS first post here hello everyone !
   / TC55DA Stuck in neutral #5
Yes bad shifter switch, I replaced with a new one now everything's good! Thanks!!!
New/Unused 78in Quick Attach Grass Fork Grapple (A51573)
New/Unused 78in...
BUYERS PREMIUM & PAYMENT TERMS (A52577)
BUYERS PREMIUM &...
1977 GMC GENERAL TANDEM AXLE DUMP TRUCK (A52577)
1977 GMC GENERAL...
Polaris Sportsman 500 (A51573)
Polaris Sportsman...
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
