TC55DA 3 pt lift issue
   / TC55DA 3 pt lift issue #1
ch1ch2
Veteran Member
DFW, TX
IH 584, NH TC33DA, NH TN95A
What does it take to fix my 3pt lift?
The pto turns some even when not engaged. Enough to spin a shredder. The lift arms do not stop. They go up or down if I lift any where between lower and rise. The draft seems to work most of the time but I can't tell with the lift lever doing it thing. If I put the draft lever in between up and down, the lift lever sometimes will not go pst the draft leaver on the rise stroke. It will always past the draft lever going down. I even had the arms up and I lowered the lift lever and the arms went haft way down and the decided to go up for not reason.
This is on a NH TC55DA. I just bought it used. It had a backhoe attached. When I took off the BH and put on lift arms I found the problem.
I am guess if I buy a manual ($300) I can figure it out. Do I need any special tools? What would this cost in a shop?
(6) Bags of Tire Chains (A51573)
(6) Bags of Tire...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
CATERPILLAR VC60DSA SHOP FORKLIFT (A52472)
CATERPILLAR...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2010 HEIL TOKEN TRAILER (A52472)
2010 HEIL TOKEN...
