TC48DA Pat's Easy Change ?
   / TC48DA Pat's Easy Change ? #1
rah6965
Carthage/Sanford North Carolina
New Holland TC48DA
I have a TC48DA with adjustable lower links and considering adding the Pats Easy Change devices. Does anyone know if they will work with the telescopic lift arms like on the 48DA tractors? My lower arms are also Cat 2, but they only measure about 3 inches high, which the mfg. says should work with the Cat 1 PEC system. Most of my implements are Cat 1, so I thought I could just use some bushings with the Cat 1 model PEC. I just need to know if anyone has attached them to lift arms of this type and how they like them.
   / TC48DA Pat's Easy Change ? #2
Pat makes a Cat. 2 (tractor end) to Cat. 1 (implement end) Easy Change. That way you won't have to have any bushings.
HOMEMADE 82"X18' DOUBLE AXLE CAR HAULER TRAILER (A51247)
HOMEMADE 82"X18'...
PALLET WITH TROYBILT TBE304 EDGER (A51248)
PALLET WITH...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2R S-TINE CULTIVATOR W/ ROLLING BASKETS (A51247)
2R S-TINE...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
2014 Dodge Avenger SE Sedan (A51694)
2014 Dodge Avenger...
