TC45DA starting problem
   / TC45DA starting problem #1
BlueCanuck
Ontario, Canada
2005 TC45DA
My TC45 is having an intermitent issue starting. My shifter from high/neutral/low has always been stiff to move between functions. Now every other start, when I place the lever in neutral, there is dead silence when I try to start the engine!!! No turning over of engine, no clicks of any sort, just that sick dead sound.......
Is it loose linkage? neutral switch ?
The machine has about 350 hrs.
Any ideas would be appreciated.
STEVE
   / TC45DA starting problem #2
Try moving the lever to see if that neutral saftey switch is not fully engaged.
I have heard there are problems with starter relays.
Check you battery, starter, and ignition for loose or corroded connections.
   / TC45DA starting problem #3
Move the lever through the neutral position while holding the key to the start position. If it starts, then you need to disassemble and clean the pivot under the left fender panel to make sure the lever moves freely and you can feel the neutral indent. If it doesn't start, you probably have a starter/solenoid problem that is common on our tractors.
It could also be the neutral sensing switch or a dirty/loose connection to the switch. It is under the left side of the operator's platform and is screwed into the transmission housing. It looks like a hex nut with two wires attached.
Also, the PTO lever will keep the engine from turning over. You might jiggle that to make sure it is in the OFF position. If it is working, you should be able to see the light cycle on and off on the dash panel as you move the PTO lever.
The parking brake and operator presence system will allow the engine to turn over, but it will not start due to the fuel solenoid keeping fuel shut off. That is not your problem if your tractor's starter will not operate.
Wolverine Skid Steer Hydraulic Drive Trencher, New (A52384)
Wolverine Skid...
2020 Chevrolet Tahoe SUV (A51694)
2020 Chevrolet...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
2013 DRAGON ROLL OFF TRAILER (A53843)
2013 DRAGON ROLL...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
John Deere 848G Grapple Skidder (A52384)
John Deere 848G...
