TC45da Hydraulic lift arm
   / TC45da Hydraulic lift arm #1
tractordansservices
new holland tc45DA, new holland Boomer 50
Hello forum,
first time posting.
was mowing with my new holland tc45da and noticed the mower all of a sudden sagging on one side. Upon inspection i noticed the lift arm broke (see picture)
wondering if anyone has any experience with removing and replacing these arms...
would this be something i could weld together and put back on?
new one is priceyyy
any info is appreciated.
thanks all,
Matt
   / TC45da Hydraulic lift arm #2
I have not had done that work. There is Circlip/retaining ring at the end of the rockshaft ( the main horizontal shaft with splines) that secure arm to the shaft. I would first put a witness mark on the end of the rockshaft and the arm to be able to put the new shaft in exact same location so two arms would have the same elevation at various height. after removing circlip then you would need to remove the busted shaft, you might need to pry it out or beat on it some. Installation is the reverse but make sure the splines are nice and clean with all rust removed. Spraying some penetrating oil to the joint and letting it soak will help disassembly.
JC,
   / TC45da Hydraulic lift arm #3
If it was mine, I would take the part to a machine shop for a professional evaluation
   / TC45da Hydraulic lift arm #4
Another option is check with some of the tractor salvage yards.... you may find one in perfect shape for a fair price. (negotiate)...
2008 Chevrolet Uplander LS Van (A51694)
2008 Chevrolet...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2014 INTERNATIONAL MA025 BOX TRUCK (A52576)
2014 INTERNATIONAL...
