flyingj
I had my tractor in the shop, siphoned out the #2 fuel and replaced with #1 for winter operation. Drained the hydraulic system and replaced with low temp fluid (Chevron THF 1000). Drove it out of the shop and ran it for about 10 minutes, then parked it in the shed. Shut down the engine at idle. Temp is about 15f. This afternoon I started the engine, after about 20 seconds, it started going faster and faster, finally exceeding the red line RPM with the throttle still at idle position. I shut it down with the key, then tried it again, same result. I checked the lever on the governor that moves with the throttle lever, it's moving as it should and is contacting the stop when in idle position. I am using rotella synthetic motor oi and it's at normal level. Anybody have an Idea what could cause this? I plugged in the block heater but have not tried it again.
The tractor is still under the 2 yr warranty, but I hate to haul it 50 miles if I don't have to. Dealer says he has not heard of this happening.
Thanks,
Jim Frisby
Palmer AK
Thanks,
Jim Frisby
Palmer AK
