TC45DA 300 Hour Service?
   / TC45DA 300 Hour Service? #1
rrs26ja
Dutchess County NY
New Holland TC45DA
I just purchased a TC45DA with 295 hours on it. I now have 300 hours on it. What service needs to be performed at 300 hrs. I assume I can do this myself.
   / TC45DA 300 Hour Service? #2
All fluids and filters.
   / TC45DA 300 Hour Service? #3
You should buy an operator's manual. Then you will KNOW the service has been done correctly rather than assuming it was.
   / TC45DA 300 Hour Service? #4
You really do need that Owners Manual as RickB said. That will not only show the schedule, it will also show you where the lube points are located for greasing your tractor. The draining of fluids is a little tricky. The engine has two drain plugs that are obvious. The transmission also has two plugs. We could be weeks trying to describe all these locations. You really need that manual.
As far as the schedule goes, I think if you lift the hood and look on the bottom side, you will see a maintenance schedule unless it has been removed.
   / TC45DA 300 Hour Service? #7
Get a owners manual and do all filters and fluids. Go to messicks.com or your local NH dealer.
Bob
Thanks all. I purchased the service manual on E-bay. I assume this info is in the service manual, if not I will either look under the hood or spend $15 for the owners manual.
   / TC45DA 300 Hour Service? #9
The maint info is NOT in my TC18 repair manual. Spend the $15 - it's nothing compared to the cost of the HST & Hydraulic filters:eek:
Deere 9965 Cotton Picker (A53472)
Deere 9965 Cotton...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2001 TRIPLE E INDUSTRIES 3-AXLE STEP DECK 48X102 (A52472)
2001 TRIPLE E...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
