joelego
I have several issues with my TC45D transmission. The tractor is two years old with about 220 hours on it. First of all I have the "HST pedal not returning to neutral" problem. It has been back to the dealer 3 or 4 times for this. Twice he adjusted and lubed the pedals. And once he replaced the transmission. Which I found out later from him, means he replaced two pumps in the transmission. On the last service call he adjusted the pedals again, but now it is very and I mean VERY difficult, if not impossible, to get it into high range unless I slightly press on the reverse pedal. Unfortunately this is an intermittent problem. Mostly showing up after i've run it for an hour or so under a light to moderate load. As best as I could, I have not found any post where this problem has been resolved to the owner's satisfaction. The "I guess I will have to live with it" solution is not acceptable. As I've come twice to nearly having a serious accident. And besides I've paid good money for this tractor. The dealer is going to replace the transmission again. They are supposed to pick it up this week when the parts come in.
The second problem is that as I'm moving along, the tractor will come to a complete instantaneous stop. The first two times this happened I was not moving very fast and immediately shut down the tractor. I got out of the tractor to look around as I thought I had hit a large stump with the FEL. Not a thing in sight. I thought I had imagined it, got back on, started the tractor up and it ran as if nothing happened. Another time I was driving down a very smooth, paved road, wide open, or nearly so, throttle, HST cruise control engaged and wham. The tractor literally jumped. It happened so fast that I could not react fast enough. The tractor did not stop or even slow down just a loud bang and a jump. There is definitely something wrong here. Again I have complained to the dealer about this but he can't find anything wrong. Of course he couldn't find anything wrong with the HST pedal not returning until I mentioned to him what I found on this web site.
Last, but not least, is the differential lock. When I engage it I hear this awful grinding noise and I have to press on it several times to engage it. Then it will not release until it feels like it, usually when I'm driving back to the barn, and then with a loud snapping noise.
I'm not sure if these are all related or all separate problems. But any suggestions would be greatly appreciated. The dealer seems to be willing to do anything to fix it but the NH Area Service Manager said that he had never heard of the HST pedal not returning to neutral problem either. So I know I can't believe any thing he says. And he told the dealer he must see the problem before he can authorize a repair. I would gladly mention his name but I don't want any flaming problems. Again any suggestions, hints, ideas or whatever would be appreciated. (Other than buying one of those orange or greens ones.)
Joe
Joe
