TC45D has occasional knock
   / TC45D has occasional knock #1
Professor Marvel
Platinum Member
Virginia near Culpeper
Ford 5000, Kubota 2150 HST, NH TC45 D, JD 375 Baby Skid Steer --- STUFF THAT GOES ON EM, Schwinn Stingray
NH TC45D 2003 1600 hrs
Recently i have had an occasional knock. It can run for a long time and once in a while a short time runs fine and suddenly it develops a knock. I always shut it off and start it up later to try to find the issue and it sounds fine again. Changed oil (shell rotella T6 synthetic and NH filter)and same problem. It does not matter if weather is hot or cold. Today I pushed snow and didn't hear any issues. When I was getting ready to shut it down I backed the throttle down and it started knocking. I speeded it up and it went away. I slowed it back down to idle again and this time it purred just fine. My friend thought it might be a lifter sticking and suggested I put fuel conditioner in.
WHAT SAY OUR EXPERTS HERE??
Thanks for any help
ordered this
Stanydyne Lubricity Formula
i will see if it helps
   / TC45D has occasional knock #3
Might be water in your fuel, have you checked the bottom of your fuel filter lately?
no but i will now. Can i just open a screw at the bottom of it and drain it?
   / TC45D has occasional knock #5
Not on mine, have to unscrew the metal ring that holds the jar on. Mine was froze like **** this week. I added Howe’s Diesel treat. Ran like a top after that, better than ever actually.
thank you for the heads up
will try that
   / TC45D has occasional knock #7
Sounds like it could be the lifters. Water or gas mixed with the diesel fuel will cause havoc too. You can try to add a can of seafoam to the engine oil. That will clean the little oil passages inside the engine.
thank you
Looks like you were all right. It was getting bad quickly and I did not want to keep trying to figure it out myself and possibly ruin what might be saved so I had the local NH dealer pick it up. It had large amount of water in the tank. I always keep it over full to avoid condensation but I guess that wasn't enough. OH also a squirrel had chewed the vent cap off my fuel cap and we have had incredible amounts of rain around here for at least a year likely contributed to water.
Anyway fuel filter clogged with large amounts of rust. Injector spring broke so wouldn't close and dumped fluid (water and fuel). He said should be fine. They are going through entire injector system since they have it. Will get it back next week to find out for sure. This guy first told me (when I said it had a knock) that if it was a bottom end issue probably best to just get new motor but not worth it on 2003 unit. SO THIS MADE ME FEEL A LOT BETTER.
Thanks to everybody for your suggestions. Would have looked farther into what you folks said but did not have confidence in myself.
Has charger with it. (A51694)
Has charger with...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52748)
2023 New Holland...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
