Tc45D 300 hour oil change
   / Tc45D 300 hour oil change #1
jtn
Illinois
New Holland TC45D
Good news for those of you planning on doing the 300 hour service on your class III boomers. I changed the transmission and front axle oil on my TC45D and it was not to difficult.
The instructions and illustrations in the manual are pretty clear. I had some trouble finding the HST filter as it is behind the left hand loader subframe. It is impossible to get a filter wrench on it so tighten it by hand for your own sanity. The Hydraulic filter, which is inboard from the right rear tire, can not be pulled out upright if you have a loader, so plan on spilling oil while removing it. The front axle center drain is easy to get to but slow to drain. The right and left drains are behind my tires (I have R4's) so I took an old funnel and cut it down to fit under the drain plugs. Speaking of which there are two plugs for the transmission that take 19mm sockets and the three plugs for the front axle that take 16mm sockets.
I used two 5 gallon buckets under the transmission to catch the waste oil. To get the bucket under the rear drain I had to remove the drawbar. The keeper bolt on the drawbar takes a 15mm socket.
I bought a cheap plastic funnel with a flexible spout and a long narrow funnel at Autozone. I used the flexible one to fill the hydraulic system (the fill cap is next to the dipstick behind the fuel tank and can not be poured directly into with a 5 gallon bucket) and the front finals. I used the long narrow funnel to fill the front axle.
I spent about 2.5 hours total, some time of which was waiting for the front axle to drain and modifying the funnel to get the front final drives.
Do yourselves a favor and have the following supplies on hand:
Flexible funnel
15, 16, and 19 mm sockets
12 gallons NH 134 Hydraulic oil (accept no substitutes)
Rags (don't be stingy here)
Oil dry or cat litter
12 gallon container for wast oil
Brake Cleaner (this removes spilled oil from tractor surfaces or from garage floor)
good luck!
JT
   / Tc45D 300 hour oil change #2
JTN,
When I did my 50 hour, I was able to use a strap wrench on the front hydro filter. I grabbed it at Autozone for $ 4.99. Its a nylon web loop with a 3/4" square steel "handle". All you do is loop the strap around the filter. wrap the excess around the steel, put a phillips srewdriver in the hole in the steel handle and twist. The handle drops down below the loader mount. Works to install too !!
   / Tc45D 300 hour oil change #3
jtn,
Thanks for the info. I like posts like that, telling me which size sockets I need and such.
What did you do with all of the waste oil? That's a big dilemma for me.
--Brad
   / Tc45D 300 hour oil change #4
<font color=blue>...Brake Cleaner (this removes spilled oil from tractor surfaces ...</font color=blue>
Hi JT...
That was a great informative post.../w3tcompact/icons/smile.gif
I would only add some caution on using "Brake cleaner" on painted tractor parts... some of this cleaner is potentially a super chemical cleaner... that will remove your paint down to the bare metal... or leave funny etched patterns on the metal... /w3tcompact/icons/crazy.gif
   / Tc45D 300 hour oil change #5
I use a product from Castle called Shop Solve. Works for cleaning everything you can think of on a tractor, dries fast and clean and doesn't harm the paint.
   / Tc45D 300 hour oil change #6
To get the oil out of the nooks and crannies, use Simple Green. Mist on, wait 15 seconds, hose off. Won't eat the paint, cuts oil and grease, and biodegradeable!
   / Tc45D 300 hour oil change #7
Tanks for the post, if I can ever get some more time to get my butt in the seat I will be racing toward the 300 mark myself.
   / Tc45D 300 hour oil change #8
Thanks for the info, JT. I'm not far behind you in hours. Last Friday I bought all my "stuff" for my 300 hr service, but I still have about 15 hours to go before doing the "deed." Your descriptions will help a bunch. /w3tcompact/icons/smile.gif/w3tcompact/icons/smile.gif
John,
Thanks for the tip about brake cleaner. I had never had a problem in the past but it would certainly be a nasty surprise. Usually I just use it for finding hydraulic leaks.
JT
Brad,
My dealer has a waste oil furnace. If you do not know someone with one try your municipal landfill. I think the one here has a special conatainer for waste oil and another for antifreeze. It may cost you some to dispose of it. One other suggestion: The farmer down the street from my old house would take hydraulic oil to run in his dumptruck. You know the saying: "One man's trash is another man's treasure."
JT
Wolverine Quick Attach Screening Bucket (A50514)
Wolverine Quick...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
Deere 317G (A50120)
Deere 317G (A50120)
John Deere 1025R Tractor (A50514)
John Deere 1025R...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
