Does anyone know the exact location of the starter relay switch on a 2006 TC45A? The solenoid on the starter makes a clicking sound when I try to start it. I’ve done multiple tests trying to find the problem. These include replacing the starter and ignition switch, neither of which solved the problem. On the advice of someone else I disconnected the OEM wire from the spade on the solenoid and ran a jump wire from the spade to the positive battery terminal. I touched the wire to post over a dozen times and the starter engaged. Unplugged the jump wire from the spade and plugged the OEM wire back in and got the the solenoid clicking sound. I repeated this entire process three times with the same end result….except it did start one time but any successive attempts resulted in the solenoid clicking. I’m told that it’s a low voltage issue from the ignition switch to the starter solenoid. If that’s the problem is there a starter relay switch that’s bad or is something else? Thanks in advance for any advice.
