tc45
   / tc45 #1
trucker12
Conway NH
TC45
Hi does anyone know where the serial number tag is located on a tc45 tractor. I found one on left hand side on the transmission but the numbers don't make any sense as far as the year it was made. Someone from a new holland parts dealer said there should be a tag on the frame of the tractor not on the loader. I haven't been able to find it.
   / tc45 #2
On my dx 40 made by same company it is easily visible on the frame left side just in front of front axle.
   / tc45 #4
From reading on line I think you have the right tag on the transmission. Not sure how to determine the year but on my tag the second number is an 8 so i assume it means 2008 that is what my tractor is and it is the only 8 in the number. I also have a number for the transmission and engine on the same tag.
   / tc45
My tag says Tractor number: G525268 Model: TC45s so maybe mine is 2002. I have the hood with the 2 square headlight lens. I bought the tractor used and the person didn't have the paper work but thought it was 2000 or 2001, they bought it new. From what I have found out so far, Is that differant models like the tc45 tc45a tc45d all had differant headlights from year to year. I haven't found a tc45s yet so don't know what that means for my tractor. I know from looking at the tractor specs on tractor data that the tc35 ,tc40, and tc45 all use the same chassis. Hope this helps. I'm looking for the year so i can buy a repair manual for the right tractor and to buy parts should i need them. Also i've read some post about super-steer, how can i tell if mine has that. Thanks
   / tc45 #6
Supersteer front axle pivots in the middle, as well as each wheel turning as a car's front wheels. Can't help w model/serial #.
Jim
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
WB Mower (A50120)
WB Mower (A50120)
FRONTIER  ROUND HAY BALE SPREADER (A52472)
FRONTIER ROUND...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
