TC40DA - Work Lights
   / TC40DA - Work Lights #1
602466
Silk Hope North Carolina
New Holland TC40D
I am putting work lights on my tractor. Looking at the fuse digram, they list two fuses for work lights. One 10 Amp turn signal, rear work light and the other 15 Amp, front head lights, auxiliary rear work light. Which one is wired to the bullet connector just behind the seat? Do I also need to wire in a switch or will they work off the headlight switch?
Thanks,
Wally
   / TC40DA - Work Lights #2
My schematic shows the rear work light is wired to fuse #3 in parallel with the turn signal/flasher. You will have to add a switch to the rear work light because the connector is powered anytime the ignition switch is turned on. You can easily verify this with a voltmeter or test light in the connector behind the seat. Turn the ignition on and check for voltage. Then, pull fuse #3 and see if the voltage goes away.
Komatsu Midi Excavator (A51691)
Komatsu Midi...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50323)
Pitts Tri-Axle RGN...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
2010 Ford F550 Service Truck (TITLE) (NOT RUNNING) (A50774)
2010 Ford F550...
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A51692)
2015 Ford F-550...
2016 Ford Explorer...
