TC40DA PTO Light Won't Shut Off
   / TC40DA PTO Light Won't Shut Off #1
fishguy10
John Day, OR
Kubota m7950, NH TC40DA
Hello! I have found this forum to be the best on the net for solving problems with my TC40DA but have run into one that even following all the pointers here that I found with the search engine haven't fixed.
A prior owner jumpered the PTO safety switch and the terminals eventually became corroded. Because my kids are running all the equipment I thought I would reconnect the 4-terminal pigtail to the switch. When reconnected, it would work only as long as I continued pressing the pigtail in by hand. Multiple cleanings failed to get an adequate connection. Consequently, I noted the wire numbers, clipped the wires and installed new spade terminals and reconnected. When I did, the PTO light would no longer shut off in any position or when the switch was pressed by hand.
I previously installed a circuit breaker in fuse position number 2 and have also tried a fuse. The switch tested fine. Switched out the PTO relay with another; no change and tested the relay with a 12 volt source; closed just fine.
Unfortunately, my owners manual wiring diagram only shows two wires going to the safety switch and I have four (two white, two orange), two numbers that match the book and two that aren't anywhere in the book. Only one of the white wires are hot with the key on.
Any thoughts or advice would be greatly appreciated.
   / TC40DA PTO Light Won't Shut Off #2
try using a ohm meter on the 2 wires coming off of the pto lever. it should make the needle move on the meter in the on position and go back to zero in the off position. if it stays on all the time the contacts in the switch are probably fused together. that would make your light stay on all the time.
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A53473)
Michelin CARGOXBIB...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
New Holland B95 Backhoe (A50490)
New Holland B95...
2014 Morooka MST1500 Crawler Carrier (A52384)
2014 Morooka...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2019 KENWORTH T680...
