SuperCobra
Good evening,
First let me say that I think I've found all of the various TC no start threads on here and appreciate everyone's sound advice. That said, I haven't had time yet to systematically check everything, the tractor is stuck out in the field and I get home after dark, I'd like to narrow down the parts I buy and frankly, I suck at troubleshooting. I hoping this knowledgeable group can help me shortcut some steps:
Here are the symptoms
1) Ran fine, never had any start problems.
2) Shut it off for a half hour, went to start it, turned the key, nothing other than small movement on fuel gauge and tach needle coming off the peg. Not even a click on starter.
3) Cursory glance at battery terminals and ground to frame looks good, tight and clean (didn't take cables off and clean them though).
4) After time on the battery charger and even fifteen minutes being jumped, still no start. However, small improvement in that the starter (solenoid) now clicks somewhat rapidly when I turn the key.
(I have noticed that when I first turn the key I get dim dash lights and the needles barely move and then after a five seconds or so the needles (fuel and tach) climb up where they should be and I get a hum/buzz noise from under the instrument panel. It also seems like the lights get brighter (but still very dim) after the same amount of time.
5) No flashers - key on or off (rules out an ignition switch problem?).
6) I have a Ohm meter and think I can use it correctly and even know where the fuses/relay are - I just haven't had the time to get out there.
I've read all the posts about bad ignition switches, bad batteries, bad cables, bad ground, bad #2 fuse, bad neutral relay, solenoid wiring fixes, self-resetting CBs instead of fuses, etc., etc.
(thanks Jinman and others).
My questions:
1) My previous experience with batteries is that even if bad you can usually jump them correct? So I'm assuming if it is a battery related problem it is with battery connections or cables
2) If the #2 fuse is bad or neutral relay you won't get any noise out of the starter/solenoid correct but all of the gauges/lights should function as the always did?
3) If bad PTO or or seat safety engine still turns over right? How about with the neutral start?
4) To verify the starter isn't bad I can just take run the positive jumper cable from the battery to the big post on the starter correct? And if it is a battery/battery cable or connection problem can I verify that by just running the positive cable from the jumping vehicle's battery to the lug on the starter?
Sorry for questions that may seem obvious to some. Not meaning to come across as lazy, just trying to trouble shoot from a distance since I have limited time to out to the tractor and the parts store.
Thanks in advance,
Randy
My questions:
Thanks in advance,
Randy
