TC40D
   / TC40D #1
benewton
New Hampshire
TC40D
Given that I took a bit of grief on the cost of the unit, with the 16LA, TNT, and LP3584.
Given that I'm a first time buyer, owner, and operator.... With all that implies.
And given that I make not a dime from the beast.
And though it's only winter, and so there's only snow to move, I have to admit I love the damned thing!
Thanks for all the help, through your threads, discussions, and so forth. I wish I had something to add...
   / TC40D #2
Bruce,
Glad you are enjoying your tractor so much. I just visited mine in the garage to keep it from getting lonely! You might have to invent some work or perform some light maintenance. Check the tire pressure? Oil, etc.
Peter
   / TC40D #3
I have the same tractor and I'm with you, I love it. After going from a ferguson 30 (wish I still had so I could restore it) to a TC29 gear to this one has been one of the best things I have done.
   / TC40D
Grease gun in hand, the 16 gets done every 8 hours....
With 30 or so hours in hand, the 50 hour "refill" is in my mind's
eye...
And the (loaded) rears were reduced from 24 PSI or so to 12....
Works better that way!
Did rear work lights too, though they mount on the ROP's mount,
deleted the standard plug, and could be a lot cuter. They too,
work, which is the minimum for the beast, otherwise known as,
depending on the audience, the tractor, or Huey.
Picture to follow, I guess, although, as a fairly much stock beast,
there's little point to the exercise.
Except, of course, he's mine!
   / TC40D #5
Any picture with a tractor in it is a good picture. Bring'em on.
   / TC40D #6
Hey where's that picture, I received a conformation a while back that I thought was a picture,but nothing. Maybe your to busy playing to post a pic.
   / TC40D
Had/have a problem with transmitting .jpg pictures....
I might make my living with them, but one can easily learn to hate these damned boxes...
Anyway, here's one from above, if it comes through, prior to doing the rear lights.
Attached a pair of halogens to the ROP lock down points a bit later: there are plans for later work,
but, for right now, Huey does snow!
   / TC40D #9
Will the third time be a charm?
   / TC40D
Na, no luck...
If I can get away from the engineering crap that they pay me to do, I'll have to investigate format converters...
2019 JOHN DEERE 843L-II FELLER BUNCHER (A51242)
2019 JOHN DEERE...
CRATE OF MISC HYD HOSES (A51244)
CRATE OF MISC HYD...
2014 Ford Fusion (A50324)
2014 Ford Fusion...
Bucket Bale Spear (A50515)
Bucket Bale Spear...
TRAILER AXLE (A51244)
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
