TC40D VS TC55DA
   / TC40D VS TC55DA #1
FULLPULL
Ky
TC55DA
Ater using both the verdict is no contest . I miss the hydrostat but the ehss is smooth . Both tractors have there place doing some of the same type loader work.The 55 has more hp and hauls more the 40 gets closer to objects and seems to like stops on hills better. They both manuver good but the 55 has alot more speed choices with the power to work . I miss the 40 dual power on the joy stick i find myself wanting to change speeds there. Also i was a left hand person on a right and machine the controlls are different in a day or so i should get this down. There was no steering issues or ehss on the 55. The weight of the tractors the 40 had calcium in the rear tires it would handle itself good the 55 needs the tires filled yet to see how stable it is going to be.So far i would buy either tractor again .Both tractors do alot more than they should for there size i guess i say that since i used an older ford 2wd for many years.It would break a axle on level ground if you didnt take it slow but we got the job done and thats what counts .
   / TC40D VS TC55DA #2
Your right full pull; There is no contest. The 55 has more weight, power, loader ability, and more rubber on the road. The larger front tires seem to work much better in soft soil. The turbo whine is unmistakable and seems to carry the torque band without bogging down. The hydro is fine in my 4110 JD for lawn work but the solid transmission for loader work and pulling applications is paramount. The hydraulic pump for the loader works smooth and responds to the application quickly with force to make the operator look like a professional. Near as I can tell it is easy on fuel and turns on a dime with excellent stability. Then again I might be a little bias.
   / TC40D VS TC55DA #3
Yes, EHSS is very smooth. I did not realize how nice it was until I owned one for awhile.
Bob
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
1998 C6500 Chevy, 3126 Cat Engine (A52384)
1998 C6500 Chevy...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 Isuzu NRR Roll Off Truck, VIN # JALE5W169K7901549 (A51572)
2019 Isuzu NRR...
