TC40D Hydraulic Problems
   / TC40D Hydraulic Problems #1
Qapla
Veteran Member
Gator Country
New Holland TC40D HST 4WD FEL/BH
We have a TC40D with FEL and BH.
We were using the tractor when, suddenly, with no warning, the FEL quit working. No response to the control at all. There does not seem to be a broken line and no fluid spill was seen.
I tried to back the tractor out from where I was working since the rake on the FEL would be able to drag on the ground. The tractor will not move! At first, it seemed like it wanted to - now, nothing, noting at all - no groan, no whine, no movement.
The dipstick shows a level between the two marks.
Could it be the pressure relief valve or the pump?
Any ideas?
UPDATE:
We found it!
Seems there is a rubber T underneath the tractor that is not readily located. It was pulled off and is on the suction side. After we got it back on and everything put back together it works like it used to.
We did have to top off the fluid level and change the fuel filter while we were at it ... all-in-all, a simple repair
   / TC40D Hydraulic Problems #3
I have a NH 3040, that is a newer version of your tractor. Is there a chance you could post a picture of what you described? Thanks.
   / TC40D Hydraulic Problems #5
Kinda looks like the T might have softened or degraded over time maybe put in in you next P.M. if it did it once it might do it again . Just a thought when the clamp leaves grooves in the hose it's usually shot.I'd keep an eye on it .:drink:
2005 Great Dane Trailer, VIN # 1GRAA96265S700587 (A44391)
2005 Great Dane...
2007 Peterbilt 335 Mickey AO-A Battery Truck (A44571)
2007 Peterbilt 335...
2008 UTILITY 53X102 DRY VAN TRAILER (A43004)
2008 UTILITY...
2014 UTILITY 53X102 DRYVAN (A43004)
2014 UTILITY...
2012 FREIGHTLINER M2 STAKE BED 24’ LENGTH (A43004)
2012 FREIGHTLINER...
Chemical Containers 1,000 Gallon Pul-Tank Towable Orchard Sprayer (A44571)
Chemical...
