TC40D HST problem- HELP!
   / TC40D HST problem- HELP! #1
Porkie
Bronze Member
Carthage, Missouri
2000 New Holland TC40D-HST
I haven't posted in a long-long time but I have a problem and need some ideas!
My HST doesn't release completely when I take my foot off of the go-pedal: It will creep very slowly but doesn't stop. If I hit the brakes, it will stall the engine. To stop completely, I must take the trans out of gear into neutral.
I have had the tractor since new, in 2002 and it only has 1,200 hours on it. It has had 2 complete services, with all fluids and all filters changed and is in great shape other than this new problem. Hyd fluids are all full and there are no leaks.
I haven't looked to see if maybe some fescue or a stick may be lodged somewhere and not allowing the pedal or linkage to disengage completely. It may be a stuck HST valve????
I would really appreciate any comments!
Thanks, Sam
   / TC40D HST problem- HELP! #2
There are many here with hydros, but it sounds like all you need is a good cleaning, and lube on your linkage. Have you done that yet?
   / TC40D HST problem- HELP! #3
Sam, follow this link to a thread with info. In the linked thread, there are other links to read. By the time you finish reading, you'll be an expert. What is wrong is your HST pedals are out of adjustment. I suspect the locknut came loose and now the adjustment has changed. It's easy to fix. After you read the threads, if you need more help, give us a shout.
HST Pedal/Creeping
1996 STOUGHTON TRAILER DRYVAN (A53843)
1996 STOUGHTON...
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
2004 Ford F-550 4x4 Auto Crane 4004EH 2 Ton Crane Service Truck (A51692)
2004 Ford F-550...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
