TC40D Front Differential Bearing Shims Replacement
/ TC40D Front Differential Bearing Shims Replacement #1
Korishan
Gainesville, Fl
TC40D
Hey all,
I'm getting closer to putting this thing back together. However, I do have an issue at the moment. The shims that I had to take out got damaged and several of them rusted up pretty decent over night.
What I was wondering is if it would be possible to use a Truck differential bearing shim to replace them with? I know the thicknesses from Messicks, and I know the ID/OD from the bearings listed at Messicks (which, I got the bearings at OReilly's; saved about $75)
I did go to OReilly's and look at a few of their shim kits for the Ford 8.8 and 7.5 rear ends, however, the ID is too big/small (respectively). Unfortunately, they can't look up shims by size like they can bearings.
So, does anyone know where a good place to get shims, or know what the part numbers would be in the automotive parts stores to get these?
Thanks,
Kori
/ TC40D Front Differential Bearing Shims Replacement #2
I’d start by looking at McMaster Carr. They have just about any hardware you can think of.
McMaster.com
Thanks 3Lfarms. I went to the site and they only sell the shims in packs of 5. And, the sizes don't match up between ID/OD.
Here's what I need:
OD: 80mm
Thick: 0.1, 0.2, & 0.5mm
Ok, so I got the ID/OD from the differential bearings that would be used. On Messicks, they don't show the ID/OD of the shims. So, here's another question I have. At OReilly's I can get the ford 8.8 shims, however the ID is closer to 53-55mm. Would that cause too much slack in the shim on the differential shaft?
I suppose I need to measure the old ones to see what those were. I'll have to do that tomorrow.
/ TC40D Front Differential Bearing Shims Replacement #4
McMaster.com
@3Lfarms: As I mentioned in my previous post, I already went there and they don't have the size I need. I can either get the ID but not the OD, or the OD and not the ID.
/ TC40D Front Differential Bearing Shims Replacement #6
I don’t know why it double posted. Sorry about that.
2017 JLG G5- 18A TELEHANDLER (A59914)
2017 JLG G5- 18A...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
2022 EZ-GO ELITE...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
20 Yard Roll Off Dumpster (A65579)
20 Yard Roll Off...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
