3-Point Hitch TC40D 3pt doesn't lift with a load
   / TC40D 3pt doesn't lift with a load #1
CLETTSIII
NH TC40D
I was snow plowing with my back blade when all at once the 3pt Hitch refused to lift the blade. No warning signs before hand. The FEL works fine and the hydraulic oil full. When I removed the back blade the lift arms moved up and down freely by hand (engine off). The arms rose slowly when the engine is running. There are no other unusual symptoms. Any ideas?
   / TC40D 3pt doesn't lift with a load #2
Do you have rear remotes on the machine? If a rear remote is pushed to a detent the 3PH won't lift.
With a loader, another possibility is described by RickB in: 3pt hitch won't raise that will cause the same problem.
   / TC40D 3pt doesn't lift with a load #3
My money is on what Chris suggested. Do you have a remote controlling a hydraulic chute rotator. If it is slightly out of position, that could cause the problem. A little condensation and freezing in the remote could cause it to stick.
The fact that your FEL works says that your hydraulics are working fine, something blocking flow to the 3PH and my bet is it will be remotes.
Thanks for the advice, Jim and Chris. I do have a rear remote and the tractor has been out in some nasty freeze and thaw weather. I'll check it out this weekend and let you know what I find.
Chip
   / TC40D 3pt doesn't lift with a load #5
Chip, I was concentrating on your problem and forgot my manners.:eek: Welcome to TBN! Tell us a little about yourself in your profile if you don't mind. Fifty acres is a lot of property. My wife and I used to have 55 acres, but we've sold it off down to 22 acres.
2019 CATERPILLAR 930M WHEEL LOADER (A51242)
2019 CATERPILLAR...
UNUSED JCT SKID STEER QUICK ATTACH 72" TILLER (A51244)
UNUSED JCT SKID...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
UNUSED AGT DM20 EXCAVATOR (A51243)
UNUSED AGT DM20...
3 pt Aer-Way (A50514)
2012 CHEVROLET SILVERADO 2500HD (A50854)
2012 CHEVROLET...
