nickel plate
Veteran Member
I currently have one set of remotes (07.06 FIRST REAR REMOTE VALVE KIT, SELF-CENTERING - 710366036) and a Woods BH90-X backhoe running off of the hydraulic manifold block next to the right rear tire on my 2002 TC-40. All is well with that set-up.
I have purchased and plan to add a second set of remotes (07.07 SECOND REAR REMOTE VALVE KIT, SELF CENTERING - 718334026) to run the already purchased top and tilt cylinders. The attaching progression is, starting from inboard, hydraulic manifold block body, first set of remotes, second set of remotes and capped/covered off with the Woods' two outlets.
Has anyone done this yet? Seen one done or know anyone who has done it?
The reason that I ask is because I'm having second thoughts about the lengths four 8mm mounting studs supplied by NH in the second remote kit as the stock NH valve cover plate that moves progressively from the first remote to the second remote is 1/2" thick. This 1/2" thick NH valve cover is discarded when adding the Woods backhoe hoses and replaced with a Woods 1" thick valve cover which now adds 1/2" in length to the stack.
Woods didn't know that I had an optional first remote set when they supplied the four new mounting bolts and NH didn't know I had a Woods BH stacked on the first set of remotes when they sent me the second remote set mounting studs.
For some reason the first set of remotes mounted with four 8mm bolts. The second set of remotes are mounted with four 8mm studs. In both cases, the bolt or stud that mounts in the lower aft hole is quite a bit longer than the other three.
Does NH sell a third set of remotes for the TC40? If so, I could if needed buy those four bolts to gain added length.
The two sets of remotes will go unused when the backhoe is on and the box scraper with top and tilt is off.
I contacted Woods and they had no answer other than it's a NH issue. NH has no tech help that I know of and my dealer has proven in the past to be unhelpful.
I thought I'd post this before I pull the RR tire.
