djaustin
My son experienced a casuality on my 05 TC40 DA. < 500 hrs. While pushing a stump, the left lift arm cylinder hose burst. ( 3/8" 3000 PSI) He replaced the hose and continued without incident for aprox 15 minutes, then lost all hydraulics to the FEL and rear remote. Tractor drove fine however. Then he called me- I found a low hydraulic fluid level. (loose fitting allowing the hydraulic fluid to drip slowly out) Refilled but bucket would not lift. Finally with high RPM, bucket began shaking and slowly lifting. Topped of hydraulic sump to proper level again. Finally bucket came up, and held. Bucket tilted fore and aft fine, but raising was still a little shakey. Raised up and down several times to bleed air from system as per NH manual. Parked tractor in shed. Next day, had the same symptoms when raising the bucket, and bucket would drift down fairly quickly. Sump level is correct, I checked the slotted plug on the control block underneath the right side of the tractor, and it was in the correct position to allow flow to FEL remote and then to rear remote. Hydraulic pump visually looks fine, but somewhere there is a noise I never hoad when accuating the FEL control valve. (tinny, ratteling noise, air still in system maybe? ) Any Ideas anyone? Thanks
