TC35DA Slowed down quit and now will not turn over
   / TC35DA Slowed down quit and now will not turn over #1
dgrammar
texas
new holland tc35da
I had just rebuilt the hydraulic pump and put it back together. It started fine ran fine, hydraulics were working, engine started slowing, bucked and lots of smoke out the exhaust and died, will not turn over. I removed the hydraulic pump but no change. oil ok, etc.
any ideas?
   / TC35DA Slowed down quit and now will not turn over #2
Did your engine fail to turn over when the hydraulic pump failed the first time? If not, what made you think it might be your problem now? Why didn't you just grab a socket and ratchet and turn the engine with the pulley on the front of the engine's crankshaft? Heck! I can squeeze the fan belt on my tractor and just rotate the fan to turn the engine over a bit to see it is not locked up.
I think you have a simple electrical problem. When you turn on the key, does the PTO light illuminate on the instrument panel. If so, change fuse #2. Otherwise check your battery for 12.5 volts or above and make sure the terminals are clean and the battery terminals are clean. Remember, if your PTO is engaged or the Range lever is out of neutral, your engine will not crank over. If the PTO light is on when the PTO is not engaged, replace fuse #2 below the instrument panel.
The engine tries to turn over but only rotates a bit. no mechanical noises etc. the only thing that changed was the pump and I thought maybe it froze up. definitely not an electrical problem. I have not tried to turn the engine over by hand. Will do so tomorrow.
   / TC35DA Slowed down quit and now will not turn over #4
What has your weather been like temperature wise? Could you be gelled up? Just a thought.
Checked engine rotation with socket. It rotates freely about 1/2 turn both directions and stops solidly.
Any ideas on what might be bent/broken before I tear into it? I have rebuilt many gas engines but never got into a diesel before.
   / TC35DA Slowed down quit and now will not turn over #6
did you check engine oil level? I'll bet that it's over full (with hyd fluid). Hyd pump probably puked a seal, sending hyd fluid into crankcase. Too much oil & it went thru PCV passage into intake causing hydraulic lock... I HOPE I'm wrong because that probably means a bent con rod. Take all injectors out and crank engine with wrench - see if oil shoots out injector holes...
   / TC35DA Slowed down quit and now will not turn over #7
+1, Great advice! Many people see the outer seal on the hyd pump blown and change it. Unfortunately, their inner seals are also blown and in need of replacing. This leads to a premature 2nd failure with exactly the results you describe.
thanks, I suspected some sort of hydraulic lock. I will check it out tomorrow.
   / TC35DA Slowed down quit and now will not turn over #9
pull the injectors or gp's if it has em and then roll over..
   / TC35DA Slowed down quit and now will not turn over #10
So, dgrammar - what's the verdict??? Inquiring minds & all... hope you're back up & running!
1268 (A50490)
1268 (A50490)
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
SHOULE PWD-10 LOT NUMBER 133 (A53084)
SHOULE PWD-10 LOT...
