GOM
TC35DA GITTIN ER DONE!!
After posting back in February about trading the ole 4000 gas for a 35 DA, I wanted to touch base and share my thoughts about the investment. Took a while to get the feel of this tractor taming hills pulling a box blade or double roller Gill. It handles ,turns and pulls and pushes a lot of dirt when I hit job sites. It`s so nice to load and unload from the 22 ` gooseneck compared to the old gas tractor. Also rolling down the highway with loader,pulverizer and boxblade its comfortable to trailer. Really like the way the brakes lock on hills (I still drop the implement) when I have to dismount . Discovered a 12V DC plug behind the seat a week or so ago. This tractor is obviously built and designed for work. My neighbor liked it so much he went and bought exactly the same unit. The loader is amazing how quick I can move a tandem load of dirt where it needs to be ,then quickly smooth er out with the pulverizer. The T4 tires pull very good and are easy on lawns when having to be on them. The front tires don`t tear even when you crank it all the way to make a tight turn. In short, what a nice tractor with ,as far as I`m concerned, better looks than the competition, gutzy, beefy little three cylinder Subourah loves to work all day. At first I didn`t like the diesel tank in eye shot of my implements but now I appreciate the location simply because I`m not cooking my fuel directly over the mill(also I`m lead to believe cool fuel makes more ponys),correct me if I`m mistakin. I do have a question for the veteran owners , I don`t like running high RPM`s, I prefer feathering the hydros to keep my RPM`s at about 18 to 2000 (less bouncy when changing directions....) Like my Cummins this motor doesn`t seem to resist lugging (within reason I might add). Regards , Mark
