TC35D won't fire
   / TC35D won't fire #1
tractorblue
Bronze Member
Van Alstyne, TX
New Holland TC35D
Tractor was running fine, turned it off for 20 min now it wont fire. I charged the battery and the engine cranks fine. I replaced the fuel solenoid with a spare and opened the air bleeder and its pumping fuel while cranking with the ignition switch. I drained the fuel bowl thinking it may have sediment or water. Most all my safety switches are bypassed.Got a ton of work to do with a deadline of Friday so pretty aggrevated. I've owned it for 22 years and pretty well versed with all the issues; I've always been able to eventually get her fixed. I'm baffled. I'm 64 so maybe something is slipping my mind? Inputs please!
PS- I had parked the tractor on the side of a terrace so its slightly tilted to the left maybe 15 degree. It has almost a full tank of gas but is there anything in the fuel system that would attribute to air in the system?
   / TC35D won't fire #2
"Pumping fuel while cranking"? Assuming that means pumping out the bleed vent on the injection pump, not to the injectors? Yes/no?
You replaced fuel shut off solenoid, and of course verified that there is battery voltage TO said solenoid while cranking?
   / TC35D won't fire #3
Be sure the air cleaner is clean - no air, no fire. Check battery voltage while cranking. If too low it may not spin the engine fast enough. Clean and tighten terminals and ground terminal if voltage is good.
   / TC35D won't fire #4
I would REMOVE the solenoid while troubleshooting..
I would REMOVE the air cleaner while troubleshooting..
Loosen the lines AT THE INJECTORS and crank the engine..
Once u get fuel spurting out of the loosened lines.. NO AIR.. tighten up the lines and she should start..
THEN work backwards..
Install the air cleaner.. wait a minute or 2 to see how it acts..
Move onto the shut off solenoid..
Good luck
2001 J ODell 16ft Enclosed T/A Trailer (A51694)
2001 J ODell 16ft...
UNUSED CFG QK18R EXCAVATOR (A51247)
UNUSED CFG QK18R...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
SHOULE PWD-10 LOT IDENTIFIER 120 (A53084)
SHOULE PWD-10 LOT...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
