TC35d Pump shaft Seal
   / TC35d Pump shaft Seal #1
horsekick
Central, MO
NHTC35d ACD17
New guy here. I have a TC35d that is blowing the hydraulic pump shaft seal. I have attached a pressure gauge to the rear remote and the system pressure reads 1900psi just above idle. I'm getting ready to remove the pump for the second time and need to figure out what is causing the seal to blow.
The tractor has the 16la loader with joystick control on it also. Is there a secondary relief valve in the loader control valve or does the main system relief valve cover everything? Could a worn pump cause it? The local dealer is happy to talk about bringing it to their shop for troubleshooting and repair but not what the main problem could be.
Any help or ideas what to look for will be greatly appreciated.
Thanks, Dave.
   / TC35d Pump shaft Seal #2
If the pump is properly assembled the area behind the shaft seal should be connected to the suction (inlet) side and should never be subjected to pressurized flow. As for relief valve(s), the only one I'm aware of is in the diverter manifold and should cover all systems except steering. There may possibly be another in the loader valve, but even so, the system pressure should not affect shaft seal life one way or the other. If you're having repeated seal failures, I'd be looking for something within the pump.
2013 INTERNATIONAL SA615 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
2012 Kia Sorento SUV (A51694)
2012 Kia Sorento...
1997 John Deere 8100 MFWD Tractor (A52748)
1997 John Deere...
1998 WELD-IT COMPANY FUEL TRANSPORT PUP TRAILER (A52472)
1998 WELD-IT...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2020 PETERBILT 567 (A52472)
2020 PETERBILT 567...
