mpilihp
So I am changing my hydro fluid and filters and have a question on capacities. My manual and what Ive read online says it takes either 9.3 or 9.5 gallons for the shared reservoir. I could only fine one fill spot and the manual indicates its for both systems as they share the reservoir. I filled it with 9 gallons and checked the level and it is way high. So I fired the tractor up and let it idle for awhile to let it pump fluid through the filters and shut down and let it sit. Checked the level and still way too high.
I started to pump the old fluid back into one empty 5 gallon container I can see I did not get any where near 9-10 gallons out of the tractor. I did open both drain ports and oil came out of both.
Can anyone tell me what this tractor REALLY takes or if I did not drain it properly?
Second item is the front axle, its leaking so I know what I got out is not correct, maybe 2 quarts. Book says 6 quarts. I put 4 quarts in and checked the level and it also is over full, I'm wondering if it needs to drain down into the final drives so drove it a bit and parked it and will check again.
Question - do you check the front axle with the plug not screwed in or do you screw it all the way in and then pull out to check the level?
Second question - Can anyone tell me what the real capacity is for the front axle on this beast?
Thank You
~ Phil
Thank You
~ Phil
