TC34DA with 914 mower
   / TC34DA with 914 mower #1
expedoman55
Bronze Member
Hello, I just purchased a tc34da with 914 mmmower. I am wondering is there a way to 'lock' the belly mower up (on my tz22da there is a lock position) and the 3point arms work separately up and down then. I want to lock the mower up when I put the hoe on to keep it up out of way.
   / TC34DA with 914 mower #2
There is. The deck gets pinned up on each side. I think the pins are 5x0.5".
look above the rear of the deck and you should see where the pins go.
Fork, thanks.. does it get pins front and rear on each side ? And will the 3point still go up and down?
   / TC34DA with 914 mower #4
If it is like the 914A on my TC24D, it will only pin in the rear. Yes, the arms will still go up and down.
   / TC34DA with 914 mower #5
This is correct for my TC 34DA also.
Awesome.. THANK YOU for input.
150HP 3 Phase Motor (A53117)
150HP 3 Phase...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
2019 TOP HAT TRAILER 20 FOOT UTILITY TRAILER (A53843)
2019 TOP HAT...
CRAFTSMAN ZERO TURN MOWER (A53843)
CRAFTSMAN ZERO...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
