amarlow
Bronze Member
I am having trouble with the rear PTO on my 2006 TC34DA, and am hoping to tap the TBN knowledge base for some help and direction. Any ideas would be most welcome.
This year I decided to have the spring maintenance done by a professional, so someone with more experience than me could look for any problems or issues which I wouldn't even see. I took the tractor to a well known equipment dealer; they don't sell New Holland, but do know tractors and hydraulics. The service included oil change; replace all filters (oil, 2 hydraulic, fuel); axle fluid and hydraulic fluid check (drain a bit, look for metal flakes, water, other bad stuff) then top off; grease all fittings.
I am telling you all of this because I had just gotten the tractor back a few days before when this PTO misbehaviour showed up. I don't know that there is a connection, but you might think differently.
So the PTO problem: I am not able to disengage the rear PTO as I have been for the past three years and 350 hrs. This has only happened a few times, but has become increasingly difficult very. I rely on the rear PTO for rotary mower work, primarily. Since retrieving the tractor from the maintenance service place, l probably engaged & disengaged the PTO/mower a couple dozen times over a few days before this problem showed up.
I am not really sure how I was able to eventually disengage the PTO the times this happened. I tried a myriad of things, and not sure what worked. I changed engine/PTO speed, I shifted gears, in gear, out of gear, turned on my headlights (OK, kidding about that one). I even tried killing the engine, then moving the lever in and out, but then wasn't able to restart.
I said this problem only manifested a few times (six? eight?). During two or three of the "eventually successful" attempts to disengage, I managed to only partially disengage (I'm guessing here, cuz I don't know how the PTO drive is configured inside). I assume there is a similar spline on the interior end of the shaft that sticks out the back, and moving the on/off lever outside moves a female over that shaft to engage the spline. But these two or three times I heard very audible clicking, as if the male and female teeth were clattering over each other.
At some point in all this trial and error, I noticed I had moved the front PTO lever to the "on" position. I have no idea when this happened, and don't know whether that affected anything inside or not. This was the time I had killed the engine, then not been able to restart. When I moved the front PTO lever back the "off" position, I was able to start.
I have checked & lubricated the linkage and both pivots. I have adjusted the final linkage arm, the one connected to the shaft entering the case, made it both longer and shorter by moving the yoke a few threads (quarter inch up and down), with no apparent effect (so I put it back where it started).
Since I bought this tractor (in 2010, w/ 90 hrs on it), disengaging the PTO (ie. moving the lever at the left of the seat rearward to the "off" position) has been not exactly difficult, but certainly not easy or smooth. I only recently learned of the option of doing the engaging/disengaging at low RPM and then changing engine speed when when I was ready to use the mower. The fellow I bought it from was the one who said I needed to engage/disengage up at 540 PTO RPM (~2500 engine RPM).
I can't think of any more info which might help. I tend to write way too much anyway, but want to give all the data possible, in case one of you says, "Oh! That's the problem."
I think it's time for me to suck it up and purchase the repair manual.
I'm looking forward to any help and advice. Thanks.
~Allen
~Allen
