Oil & Fuel TC34DA Owners Manual Doesn't Mention Correct Oil for Front Axle
   / TC34DA Owners Manual Doesn't Mention Correct Oil for Front Axle #1
Norcal M5
Bronze Member
Man, I've read through the manual several times and cannot find the correct lubricant type for the front axle (has diff and final reduction gears). It could be hydraulic fluid or maybe 90W gear oil. Don't want to guess. Anyone with a similar 4wd NH that can help clear this up? :confused2:
I see that Jinman answered a similar question saying hydraulic oil. This hadn't come up in earlier search. Answered - NVM!
   / TC34DA Owners Manual Doesn't Mention Correct Oil for Front Axle #3
Do not use 90W! The front axle, diff and final drives use the standard NH 134 fluid, now available in multi-viscosity.
   / TC34DA Owners Manual Doesn't Mention Correct Oil for Front Axle #4
. . . and in case you missed it in my former post. Be careful not to overfill. The oil in the front axle should show full on the dipstick with the dipstick NOT screwed in. That ensures you have proper air space in the axle so the air can compress when things heat up. The axle is sealed without a vent. If you fill the axle with no air space, expanding fluid will blow out seals.
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
JOHN DEERE 700M LOT IDENTIFIER 35 (A53084)
JOHN DEERE 700M...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
2015 Ford Explorer SUV (A51694)
2015 Ford Explorer...
2011 Ford F-450 Dump Truck, VIN # 1FDTF4GTXBEC82149 (A51573)
2011 Ford F-450...
