TC34DA Block Heater PN#?
   / TC34DA Block Heater PN#? #1
BarnStangz
NW Ohio
New Holland TC34DA
Anyone have / know the part number for a TC34DA block heater. Poor girl started sort of rough this morning, I think moving to synthetic oil helped a little bit and I moved it from my large open span barn to my smaller shop, still gets cold in there however, I imagine it was 10* or so... So, if you guys have any part numbers and a place to get it, that would be great. I think it should help for some of these cold day. I usually get my forced air heater and point it at the injector pump side for about 15 minutes and that seems to help. Anyone else have tips for cold weather starts. Thanks for your time.
Max
Thanks!
   / TC34DA Block Heater PN#? #4
Is this an easy install?
   / TC34DA Block Heater PN#? #5
If you can reach the frost plug it is. Be real careful with the wings on the inside of the expansion screw. I ended up re-using the in-block parts of my old one, but I think the new ones will work if you're not in a rush. Sure is nice to have. Refill with water first time to be sure of no leaks.
Jim
2022 JOHN DEERE 6140M LOT NUMBER 264 (A53084)
2022 JOHN DEERE...
Cat TH407C Telehandler (A53472)
Cat TH407C...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
Ex Mark Zero Turn Mower (A51573)
Ex Mark Zero Turn...
1991 KALYN SIEBERT 60 TON LOWBOY TRAILER (A51247)
1991 KALYN SIEBERT...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
