tc33da start and stop problem
   / tc33da start and stop problem #1
karennel
tc33da will start and run but will stop on the road. If you move the neutral/gear shift it will start and go again but die in a short ways. Any help will be appreciated
   / tc33da start and stop problem #2
Check to see if the fuel shut-off solenoid is getting hot and dropping out. Although it is attached to the injector pump and will warm up with the engine, if it is bad it will be noticeably hotter. Once it cools, it will run until it overheats again. Another issue could be a fuel venting problem stopping fuel flow so try loosening the fuel cap.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A52576)
2023 EAST TEXAS...
