TC33DA Not Getting Fuel To Injectors
   / TC33DA Not Getting Fuel To Injectors #1
Ramstack
I used the tractor on Sunday and went to try and start it on Tuesday and no luck. It has been really cold here so I thought it might be a gelling issue with the fuel. Replaced the fuel filter and bleed the line out and everything seemed to flow very well. Pulled off one of the injector lines and turned it over and no fuel. Talked to the dealer and they suggested that the fuel shutoff solenoid might be bad (unitl now I didn't know the tractor had one of those). So I bought and put a new one on and still no luck. I looked through the manual and the wiring diagram looks like there is a relay in the circuit that I am wonder if that is bad. Can I use a meter and test if the solenoid is even getting power by just putting one end of the meter in the plug and using the frame as a ground? I have also had some issues shutting the tractor off and needed to toggle the key/switch several times. I didn't think much of it at the time but now I am wondering if that has something to do with what I am seeing now. Any thoughts would be greatly appreciated? Don't know a whole lot about diesels/tractors but this TC33DA is starting to make me learn...
Thanks for the help.
   / TC33DA Not Getting Fuel To Injectors #2
Yes, when you turn the key to ON, there should be 12 vdc to ground at the pin going to the fuel cutoff solenoid. That is of course if you have the PTO OFF, the Range in Neutral, and somebody sitting in the seat or the emergency brake set. From your description, I think you are more likely to have a bad ignition switch than a bad fuel solenoid. If you turn that switch to off and the fuel solenoid is still energized, there is a problem with the switch or the operator safety module. Checking to see that you have 12 vdc at the solenoid with the switch ON is the first thing I would check.:thumbsup:
2015 Dodge Journey Van (A51694)
2015 Dodge Journey...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2025 Epic Electric Cart (A51694)
2025 Epic Electric...
2011 Nissan Rogue SUV (A53424)
2011 Nissan Rogue...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
Light Tower (A52377)
