TC33DA Mid PTO will not disengage (clutch will stop it)
   / TC33DA Mid PTO will not disengage (clutch will stop it) #1
CycloneDr
Monroe, WA
New Holland TC33DA
Hi there,
Noticed on my TC33DA that the Mid PTO was spinning when I didn't expect it to be. Depressed clutch - the Mid PTO stopped as expected. Pulled on the lever to disengage, released clutch, Mid PTO spun back up. Messed with it a bit. No dice. I looked under the tractor and the lever/actuator has a screw that's adjusted all the way 'up', so no option to adjust it further. I pulled the cotter pin that holds the lever arm to the actuator and tried to move the actuator manually, to no avail at shutting off the Mid PTO. Any ideas? Other than a mild power sap, I don't think it's a huge issue to have it running. But would like it to ultimately work when commanded. Rear PTO works just fine.
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50322)
2018 Taylor-Dunn...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
2005 Featherlite Double Deck Stock Trailer (A50514)
2005 Featherlite...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
10' Feed Bunk (A50515)
2008 Toyota RAV4 AWD SUV (A50324)
2008 Toyota RAV4...
