TC33D won't start
   / TC33D won't start #1
LDuke
TC33D won\'t start
I have a 2001 Model TC33D with 85 hours on it. When I went to restart it there was an arcing sound and no dash lights or starter. In my case the main 30 amp fuse near the starter was blown. I called my dealer they initally recommended nothing except replacing the fuse. Over the next 30 or so starts I blew 5 fuses. Each time I went deeper looking for wire and connector problems finding nothing. I blew two fuses in a row and went to the dealer, the lead mechanic recommended removing the connector to the injection system to isolate the problem between starter or injection pump. I removed the injection wire and the fuse blew again, the dealer replaced the Solenoid under warranty, he said he had seen this problem once before to a TC33. So far so good. I will check some of the things mentioned in the other posts on this problem.
   / TC33D won't start #2
Re: TC33D won\'t start
If it happens again.......check your ignition switch.........That's where my "arcing' was coming from.........see the other post for more info..........Tom
2019 Komatsu PC490LC Hydraulic Excavator (A49461)
2019 Komatsu...
1273 (A50490)
1273 (A50490)
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
2012 PETERBILT 388 NATIONAL CRANE TRUCK (A50854)
2012 PETERBILT 388...
2001 INTERNATIONAL 2574 6X4 (A51406)
2001 INTERNATIONAL...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
