TC33D Ground wire
/ TC33D Ground wire #1
Eebbee
I have a 1999 TC33D that just got an hydraulic pump job and the mechanic left the battery cables disconnected. I mean the ground cable (battery negative cable) is completely off the tractor.
Now that cable is fairly short (maybe 18 inches) and based on the position of the positive cable the ground appears to have been attached somewhere on the right hand side but I can't see where. I don't see any missing bolts or bolts of the right size (for the terminal) within reach of the short negative cable. To be honest I don't quite remember the original orientation of the battery (whether the negative was on right side or left side) so I might be looking on the wrong side but I also gave a look on the left and did not see anything obvious.
Can anyone with a TC33 please share a photo showing the grounding point?
/ TC33D Ground wire #2
Mine bolts in right under where the front and the mid panels join on the right side of the tractor.
/ TC33D Ground wire #3
Sorry for the late reply. This picture shows where the negative from the battery on my TC33D is connected to the frame.
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59905)
2018 VOLVO VNL...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
