TC33D dies when warm
   / TC33D dies when warm #1
PropllerHead
My TC33D lost power slowly and died in the field after running fine for 30 min. Now it starts only when cold but runs very rough, blows smoke and only gets up to around 2k rpm. After about 2 min, it begins to idle down and eventually dies.
I tried bleeding the lines and fuel seems to flow freely from the top of the injector pump bolt. Today, after repeating this procedure, I unbolted the outgoing fuel lines at the pump and nothing is coming out.
The cut off solenoid has power and I can hear it clicking when I turn the key. I pulled it off and verified that the plunger moves with power. I can't imagine that being the problem since it always starts fine when cold.
Is my injector pump dead? The tractor is an 02 model and only has 500 hours.
   / TC33D dies when warm #2
Have you tried unscrewing the fuel cap? It might be a plugged fuel vent that is preventing fuel flow. Or it could be a colapsed fuel line.
City of Lakeland (A51691)
City of Lakeland...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2024 Kubota BX23S (Dothan, AL) (A50123)
2024 Kubota BX23S...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
