TC33D, common hyd. sump for fluids?
   / TC33D, common hyd. sump for fluids? #1
Disciple4123
I have been examining my recently acquired TC33D for hyd. dipsticks, and have just found the one with Hyd oil located behind the seat on top of the axle. Is that reservoir feeding the hydraulics and the rear axle, and the hydro trans? I was expecting to find multiple dipsticks and fill holes, but like the idea of a common fluid between systems.
Thanks,
Eric
   / TC33D, common hyd. sump for fluids? #2
The common sump/tank supplies the implement hydraulic circuit (loader, 3pt, etc.), the power steering and the HST transmission. This is pretty much standard on all CUTs.
   / TC33D, common hyd. sump for fluids? #3
On occasion the power steering is a seperate pump & seperate reservoir. Check under the hood for that... Uses the same fluid as the hydraulics.
   / TC33D, common hyd. sump for fluids? #4
Ditto.. my ex-NH1920 had a seperate sump for the pow. steering.. though used the same kind of fluid.. etc.
Trans, diffy, and lift hyds were all common sump.
front axle was of course its own sump.. haoever.. also used the same fluid.
Soundguy
Thanks. Mine has the power steering reservoir underhood separate from hydraulics as well.
Eric
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2013 Doyle Dry...
2005 Nissan Pathfinder SUV (A50324)
2005 Nissan...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2015 Ford Expedition EL XLT SUV (A50324)
2015 Ford...
1982 S&S FLATBED (A52472)
1982 S&S FLATBED...
