TC33D belly mower
   / TC33D belly mower #1
ironpen
Montgomery, Alabama
tn75s, tc33d, mc35, gt65, 6640, 3010s, TS110, TS115, TN70, Massey 5470, Kubota F2690
A friend borrowed my mower this afternoon and proceeded to jam the deck into the ground and wrap a large piece of telephone cable around one the spindles in less than 5 minutes. He noticed "smoke" coming off the deck and eventually disengaged the middle PTO. I arrived and got the cable loose but noted that turning the blade by hand didn't turn the other blades. After removing the housing cover on top of the deck the belt had come off the spindle. I got the belt back in place, but it appeared quite loose, so I went to the other side of the deck and adjusted the spring tensioner. This tightened the belt, but when I took it out of mid pto engagement, the belt was still pretty tight. Really the tension seemed about the same whether the pto was engaged or not.......Is that as it should be? How tight should the belt be....a hard answer I realize without seeing the deck. But if anybody can give me a little guidance, it would really be appreciated. Thanks.
   / TC33D belly mower #2
On both of my mowing decks (RFM on tractor and belly deck on Agco) the belt tension stays the same regardless of PTO position.
   / TC33D belly mower
Thanks for the info.
   / TC33D belly mower #4
He may have broken your belt. There are fiber strands inside of the belt, which can break even while the rubber stays intact. It's hard to keep tension on a belt with broken strands. Keep an eye on it - if it starts to slip or comes off again, replace it.
Your manual should tell you the proper tension. Deflecting not more than 1/2" with moderate pressure is a fairly common spec.
   / TC33D belly mower
Thanks...so far so good.
2016 GMC SIERRA K3500 SERVICE TRUCK (A51406)
2016 GMC SIERRA...
Unused Delta Crash...
2021 Chevrolet Corvette Stingray C8 LT1 Convertible (A51694)
2021 Chevrolet...
2012 Big Tex T/A 20 ft. Gooseneck Trailer (A53117)
2012 Big Tex T/A...
2013 Nissan Titan Ext. Cab Pickup Truck (A51692)
2013 Nissan Titan...
2017 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2017 DRAGON...
