TC33 dripping hydraulic fluid from clutch area?
   / TC33 dripping hydraulic fluid from clutch area? #1
gclark
Mount Airy, GA
New Holland TC33, Ferris IS700Z Zero turn mower
I have a TC33 that is dripping what appears to be hydraulic fluid from the drain hole located in the area of the clutch. Any ideas on where this could be coming from? I have not split the tractor yet to investigate. I am afraid it may be a seal leaking around the shaft from the rear end that goes to the clutch.
   / TC33 dripping hydraulic fluid from clutch area? #2
That is what it is and if you have 4 wheel drive it could be from that shaft. It might be hard to tell, I would change both.
   / TC33 dripping hydraulic fluid from clutch area? #3
Did you find the source of the hydraulic fluid? Did you do the repair yourself? I have the same problem and have not split the tractor yet. Any help would be appreciated.
CHALLENGER MT525B TRACTOR (A51243)
CHALLENGER MT525B...
Peterbilt 377 Semi-Truck (A52128)
Peterbilt 377...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
HYD MULCHER HEAD (A51243)
HYD MULCHER HEAD...
Ih 4300 Field Cultivator (A50514)
Ih 4300 Field...
