TC30 ROPS height with R4's
   / TC30 ROPS height with R4's #1
MDM
Platinum Member
East Ohio
Kubota L2800HST
Can some one tell me the ROPS height on the TC30 with R4's? New Holland's specs say 82.4" with Ags. I figured the R4's would lower it a little. My garage door is 82". I found 1 post that says it was a little over 84" with R4's. Is that correct? If so, New Holland's spec page must be wrong.
Thanks.
Does anyone have a TC30 with R4's they can measure for me?
   / TC30 ROPS height with R4's #3
ive got a TC33 (same tractor just a few more hp)
i can measure it this weekend for ya if no one else gets around to it before then
Thanks. ^ I would appeciate that. I think the 33 has foldable ROPS though, so it might be different that the TC30.
   / TC30 ROPS height with R4's #5
yes mine is foldable
   / TC30 ROPS height with R4's #6
I have a TC30 with r4's. I'll be in PA where my tractor is this weekend. I'll measure and post the numbers for you.
Rodger
   / TC30 ROPS height with R4's #7
I have 80.5 inches with R4's on my TC 30. 82 inch door is going to be tight.
Good luck
Rodger
Thanks Roger. Yess, it will be tight, but it will fit.
   / TC30 ROPS height with R4's #9
Thanks.
I was also worried about the height of my TC 30 with r4 tires fitting in my garage. The tractor clears the door with about 3/4" to spare! I have been storing my tractor in the garage since 2004 and I have even added tire chains and I have still never touched the door frame. I just take it slow and keep the snow and ice from building up in front of the garage door.
   / TC30 ROPS height with R4's #10
I don't keep mine in the garage, I have a barn, but it is in the garage atleast once a year, and I have to dis-connect the garage door from the opener and push the door all the way up to get it in. I could check tomorrow. sounds like next time your at the dealer , with tape measure in hand.
OK , I walked out to the garage and got my owners manual,
section 4-7
top of ROPS- rigid
Turf tires 82.9"
Ag. tires 83.8"
R4 tires 82.4"
I'd still bring that tape measure to the dealer and take a real close look at that door opening
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
Electric Concrete Mixer - (A51573)
Electric Concrete...
2021 CATERPILLAR 420 XE BACKHOE (A51246)
2021 CATERPILLAR...
2018 COLOMBO TM LOT NUMBER 184 (A53084)
2018 COLOMBO TM...
