TC30 Question
   / TC30 Question #1
Stoner
Bronze Member
Florida
I was thinking of adding a log splitter to mount behind my tractor. Does anyone have an idea as to the cost of adding a rear hydraulic kit to the tractor would cost. Is there another way to tap into the hydraulic system without the kit? What is the best way to add a log splitter to a tractor that does not have rear hydraulic ports to connect your hoses?
   / TC30 Question #2
I would have to say the best way to run your log splitter, would be to buy the rear hydraulic kit. I think that I payed $400-$600 for mine ( it was a few years ago ). I'm not sure if there is a cheaper way, but I think that this is probably your best option. I use mine with my rear snow blower, my pto chipper and my backhoe. I have to hold the lever with a bungee cord, to supply my chipper with constant hydraulic flow that it needs ( the lever that I refered to is beside the seat and it directs the flow of the fluid one way or the other. It is supplied with the kit I think) . I'm sure you'll have to do the same to give constant flow to your splitter too, unless the 3 point splitters don't have their own valve to open and close the ram. I can't remember how they are set up. I wish that I had one more set of rear remotes though. I plan to have a top and tilt set up one of these days, and for that I will need another set. You will be very happy with it. If you forsee using two someday, I would have two installed at the same time, saving a little labor, unless you'll be doing it yourself. Good luck. I hope this helped.
Daryle
   / TC30 Question #3
I just had to replace some parts on my rear delxe remote pack for my Nh 7610 late last year. Parts alone were going to be 700$.. Figure in the 800-900 $ range for your set, assuming a dual valve. If there are economy ports.. they may be cheaper.
Another option is a pto pump, spool ,a resevoir, and hoses and couplings. You may be able to rig that up for 500$ or so.. so deffinately check your spool options.. I f the rear remote is anywhere near the price of the pto pump.. go for the remotes.. you never know when you will need them.
Soundguy
   / TC30 Question #4
Boy,.. it has been a couple of years, but my remotes on my DX40(TC40) were around $300 give or take... and around 200 for each additional set, I bought only 1 set and really wish I had bought 2... they were easy to install.
I would think that the TC30 must be close to the priceing on the TC40
My log splitter was from Northern Tool
NorthStar 3-Point Horizontal Log Splitter |Log Splitters | Northern Tool + Equipment
and works great, I also use a bungee cord to keep the the lever ingaged.
Hope this helps,
Ken
   / TC30 Question #5
rear remotes kit ,about $370 in 2003 as I remember, I'd go for the PTO pump for the splitter, what can of tonnage will you generate with the tractor hyd.?
   / TC30 Question #6
I'm back, had to get my youngest to tryouts,
I did some research on this issue a while ago, before buying my splitter
My tc-30 hydraulics, 6.2 gpm. relief vavle dumps at 2100psi
4" cylinder = 13 ton
4.5" cylinder = 16.7 ton
5" cylinder = 20.6 ton
6.2gpm makes for a slow cycle time,and the larger the cylinder diameter the slower it will be.
13 ton max will not split everything you will encounter
this is why I say a PTO pump for a TC-30
the PTO pump will let you get up to 20 gpm and with a 5" cylinder give you 20 ton with a cycle time aprox. 17sec
For the monies invested in this rig you can get a 22 ton 11.4 gpm stand alone gas powered splitter for $1000, that was my choice
I don't have my tractor sitting there for hours while we are splitting
, use the tractor to get the wood, rear remotes are good
just food for thought,
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2017 FREIGHTLINER CASCADIA TANDEM SLEEPER (A52576)
2017 FREIGHTLINER...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
