TC30 10 amp fuse
   / TC30 10 amp fuse #1
beckelkamp
New Holland tc30
Can anyone tell me what is all on this fuse? Fuse blows after about 30-45 minutes of brush hogging and shuts engine down and dash gauges won't come back on. I just purchased this tractor so I have no manual or diagrams. Its the fuse all the way to the right looking head on at the fusebox. I'm guessing there is a short somewhere. Appreciate if someone could help. Thank you.
   / TC30 10 amp fuse #3
From the manual:
When looking at the fuse block on the firewall from that side of the tractor, left to right (outside position to the inside position) are #3,2,1.
#1 (inside position) 10 amp, Fuel solenoid, safety start circuit, instrument panel, gauges and indicator lights, alternator
#2 (middle) 10 amp, Headlights, tail lights, optional rear work light, turn signals
#3 (outside position) 15 amp, Hazard lights
Does sound like a short, unfortunately that fuse covers a lot of different possibilities. I would start with the instrument panel harnesses and the wire harness coming off the ignition key switch. Could be vibration triggering, I had an issue where the the wire assembly got twisted up by the ignition switch plate being loose that cause a short. Some solder and dogging down the switch's nut fixed it.
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
Bobcat Skidloader PHD (A50774)
Bobcat Skidloader...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
