TC29D throttling down
   / TC29D throttling down #1
thcri
Elite Member
Minnesota SE
New Holland TC29D, 2001
Last week my TC29D started to throttle itself down. I run the RPM's up to 2500 and you can watch the throttle itself slide back down to about 1800 RPM's. I look the cable over and the only thing I can see is the spring on the pump that helps pull it back. I can not see up under the dash without taking it all apart to see if there is a tightening screw there. Has anyone else had this experience? And why would the cable get looser after two years. I would think it would get dirty and tighter?
murph
   / TC29D throttling down #2
There may be a friction washer or nut at the throttle lever that needs some attention
Well first it looks like I put this in the wrong forum, Buying instead of owning/operating.
Anyway I guess I will have to take the dash apart to get to the throttle and see if there is a washer there.
murph
   / TC29D throttling down #4
You have to take the lower part of the dash apart (black plastic). There are friction disks, loosen a nut and you're all set. I have to do this one of these days. /forums/images/graemlins/crazy.gif
   / TC29D throttling down #5
Someone was having the same problem awhile back and posted for help. I'm pretty sure it was in the New Holland Forums. It was explaining something about a tensioning screw or something similar to what MikePA has suggested. Good luck Murph! /forums/images/graemlins/smile.gif
   / TC29D throttling down #6
Murph here's the thread that I was talking about, but by now you probably have it figured out! /forums/images/graemlins/smile.gif Here
2016 Ford F-250 Pickup Truck (A44572)
2016 Ford F-250...
2020 XCMG CV123PDU VIBRATORY ROLLER SN:JKJE03622 powered by diesel engine, equipped with EROPS, a... (A40019)
2020 XCMG CV123PDU...
Suprex Gold 15W40 Motor Oil 55 Gallon Drum (A39855)
Suprex Gold 15W40...
Gas Powered Air Compressor (A39855)
Gas Powered Air...
1999 Whitecap 191 Center Console 17ft Fishing Boat 20ft T/A Trailer (A44572)
1999 Whitecap 191...
2024 VALLEY PIONEER QSP135 WHEELED MINI CRUSHER (A45046)
2024 VALLEY...
