TC29D no start
   / TC29D no start #1
RuT
West Unity, OH
NH TC29D FWD
I have a TC29D with 750 hours. I used it last week and it ran fine. Parked it in the unheated garage. It won't start now. It cranks, kind of spits/cranks fast, spews out loads of blue smoke and generally won't do much more than that.
I cleaned the fuel filter bowl, replaced the fuel filter, replaced the air filter, bled the air from everything per manual and same thing...just cranks, spews loads of smoke, and won't go. I also checked the 5 or so fuses under the hood and they seem in order.
Everything seems in order and it has always started well. Fuel is not gelled, temps in the 30s and 40s, just can't figure it out. It ran great as always - then parked it, now nothing.
Any ideas?
   / TC29D no start #2
Sound like you have some bad glowplugs.
   / TC29D no start #3
There is probably a relay or timer for the glowplugs that isn't working. If you can, put a test light on the glowplg where the wire or buss bar conects and turn the key on to see if you have power. One other thing to try is plug the block heater in (if you have one) and let the engine get real warm and try to start it.
   / TC29D no start #4
There is a timer relay, and if it doesn't work it makes my 33 hard to start. In fact, in 30 to 40 degree weather it won't start well at all.There should be a light on the left side of the instrument cluster indicating the glow plugs are on.
I had it in the shop to have the hydraulic conversion, and was having some trouble with my relay. The shop foreman put a toggle switch on there to turn on the glow plugs. I replaced that with a push button type, in case I forgot to turn the toggle switch off.
It only takes about 5 seconds to heat in this area. And I think that is the relay setting for the 29 and 33D's.
When I get a chance to go back down there I may get a new relay and change it back. Maybe?
   / TC29D no start #5
Some of us have diesels with no cold start options, and they start just fine. I'm in florida of course.. but.. still.. some people act is if without glow plugs that a diesel would never start...
Soundguy
   / TC29D no start #6
Soundguy
That's mainly because many indirect injected diesels simply will not start without preheating. I have seen several Class II ignition switches that had the glowplug lead corrode and simply fal off the back of the switch. Check that if there is no power to the glowplug buss bar.l
   / TC29D no start
An update...thanks for all the advice...looks like you are leaning toward glow plugs and that that is where I was leaning after this morning.
I did plug the tractor in this a.m. for about a hour in mid twenties temps. The tractor did fire up and run after that - would not go over idle for about 30 seconds no matter where the throttle was set. After 30 seconds or so the engine would speed up and run as normal.
What's odd is this tractor always starts, I mean always starts in cold temps with just the glow plugs. Even if it was in the low teens and single digits it would still start without the block heater. Now, thirty degrees hits and it needs the block heater.
So, you all concur the fact that the block heater got it going that it looks like the glow plugs are at fault?
I'll check the items mentioned earlier in the thread.
   / TC29D no start #8
What kinda fuel you using?
Soundguy
   / TC29D no start
The fuel is the on road diesel that I get at the local gas station. What you thinking?
   / TC29D no start #10
The first time after changing fuel filter and bleeding would start hard anyway because of a little air in there.. Maybe now it will come out of it. It may have been something in the fuel. I have a tc33d and i needed to replace my relay for glow plugs because it was intermittent and wouldnt act right.
Mike
POWER LINE 180 LOT NUMBER 89 (A53084)
POWER LINE 180 LOT...
2005 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCEC19V35Z257979 (A51572)
2005 Chevrolet...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A51694)
2005 Northwood...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
