TC29D bad water pump
   / TC29D bad water pump #1
Tazz
Bronze Member
Texas, Montgomery Co
TC29D
It started when I noticed the tachometer wasn't showing the proper RPM's and the Gen light stayed on after start. Looked into it and found the fan belt was loose. While adjusting the fan belt I noticed the fan seemed loose and could be wobbled all around yet no leaks of coolant. I was hoping it was just the four fan bolts but knew it was more likely the pump going bad.
Sure enough the pump bearing is shot but surprising was there was still no leak. I did find the bottom weep hole was completely blocked with rust and dirt.
NH TC29D Bad bearing on water pump - YouTube
Kobelco SK200SR LC Excavator (A50860)
Kobelco SK200SR LC...
2022 John Deere 325G Skid Steer (A50657)
2022 John Deere...
2022 Ram Bighorn 2500 4X4 (A51039)
2022 Ram Bighorn...
UNUSED Clear Multi-Wall Polycarbonate Panels (A50860)
UNUSED Clear...
Anvil with Stand (A50860)
Anvil with Stand...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
