TC29D-A circuit to empty slot in fuse block
   / TC29D-A circuit to empty slot in fuse block #1
DanLebiedz
I want to add a 20 amp circuit to the fuse block for additional lighting. Can this be done? I think that i need additional wire retainer pieces that I have not been able to locate on-line.
Does anyone have any ideas? Thanks.
Dan
   / TC29D-A circuit to empty slot in fuse block #2
Just put an inline fuse holder for your circuit and take it off any battery hot source. Make appropriate notations on your schematic diagram of course for future owners of your tractor.
   / TC29D-A circuit to empty slot in fuse block #3
Dan
You could install a extra fuse block from painlesswiring.com or you can find one at boating stores
Let me tell you what I did though. I put a new 20 amp rated switch push /pull type from NAPA, This is also a two postion switch. I can run just the front lights or the front and rear together. I put it beside my factory headlight switch. I got power from the hot lead on the Alternator and found a good ground nearby. I used a 20 amp spade fuse and holder. This is safe and works great. The only down side would be if somone turned your lights on and ran the battery down. I have not had any trouble with that but I do have plans to either use a master cut off at the battery or just put a key type on/off switch on the dash to lock it out. kids will play at some point.
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
2024 Greatbear 72in Vibratory Roller Skid Steer Attachment (A51691)
2024 Greatbear...
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
UNUSED HURRICANE MSC2020F ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
