TC29 Freeze Plug
   / TC29 Freeze Plug #1
tow653
Gasconade County,Mo
New Holland TC29,Ford Jubilee
Went to install block heater on tc29,and the freeze plug fell inside block. Tried to bend to get back through hole,but no luck yet. Since that is just the water sleeve,can I just leave it alone and install block heater in its place? Thanks,Tim
   / TC29 Freeze Plug #2
Could you use a pair of tin snips or other type of cutting plier to get at least a partial cut on the plug? That way you might be able to bend it enough to get it out.
   / TC29 Freeze Plug #3
Get it out. If you can get it side ways in the hole grab the lip with a pair of vice grips and pry it out.
Bill
   / TC29 Freeze Plug #4
It's steel so get a magnet on it and pull it to the openig and pull it out. That happened to me when I installed mine and I got it out real easy.
   / TC29 Freeze Plug #5
Unfortunately, you need to get it out. Otherwise, you can end up with an air pocket, or just a plain old hot spot where coolant isn't flowing past an area. Uneven heat equals uneven expansion, equals improper fittment, equals uneven and premature wear. It may involve another hour or two of swearing, but you'll need to pull it out. Finding ways to bend it are your best bet. Once is starts to take the shape of a taco, you'll be able to pull it right out. Sometimes frustrating, but always worth it to know that the job is done right.
   / TC29 Freeze Plug #6
And be super careful lining up the new one- fit is quite fussy as I recall. I had to reuse the old wing keeper from inside.
Jim
New 2025 NextGen 7x16 Utility Trailer (A51573)
New 2025 NextGen...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
(APPROX 100) UNUSED FUTURE 10' GALVALUME STEEL (A51248)
(APPROX 100)...
